rroy58
#1 Posted : 12 years ago
rroy58
I have a stackable GE gas dryer that runs just fine but is not heating.It was working normally up until a few weeks ago when the gas Co. moved the gas meter. I didn't have gas for a couple of weeks while they took their time doing the job.Anyway I ran the dryer on the no heat cycle quite a few times.Now that the gas is back on the dryer won't heat up on any setting.Any ideas? Thank you.
rickgburton
#2 Posted : 12 years ago
rickgburton
Groups: Expert
Is the gas valve turned on for the dryer? Can you see the igniter turn on and glow red?
rroy58
#3 Posted : 12 years ago
rroy58
Yes the gas valve is on. I haven't looked at the igniter yet,I need to find out where it's located and how to get to it.Sounds like a good project for the 4 day weekend.
rickgburton
#4 Posted : 12 years ago
rickgburton
Groups: Expert
Bottom right side. When you take it apart you'll find the tech sheet for your machine. It should have the instructions for starting the built-in diagnostic test.
rickgburton attached the following image(s):
rroy58
#5 Posted : 12 years ago
rroy58
Thank you very much Rick. I will do that this weekend.Hope you have a good Thanksgiving.
