dmck1nney@netzero.com
#1 Posted : Friday, September 25, 2009 1:12:29 PM(UTC)
Brand new stove voided the warrenty when i installed my own orfices for propain only thing wrong is the stove is putting off 6" flames. No matter which way i turn the nut left or right, less gas or more gas i still get 6" flames i think I have a faulty factury defect they want 80.00 to come look see. no one will give me low down on if that is the only adjustment for oven flame control all other orfices are fine regulater has been reversed open side toward reg. and burner ports all working fine. please help.
#2 Posted : Friday, September 25, 2009 6:26:29 PM(UTC)
How did you convert the range, which parts you replaced and what are the part numbers?
#3 Posted : Wednesday, September 30, 2009 10:50:43 PM(UTC)
converted from natural to Lp, changed regulator by turning hub around so that the solid end is toward the regulator. used L.P. conversion kit ESPN:316243723 /Mueller p/n:LP3755BW. I have finally gotten a responce from the dealership. They are going to replace the oven spud/pin assembly ??? . tried to tell me I stripped the thread or I punched the hole bigger by raising the sleeve too high. didnt fly since i never touched the oven oriface at all before i fired it up to cook my biscuits, and the flames put a camp fire to shame. I comitted the cardinal sin of not reading my manual cover to cover untill I saw there was a problem. Then I saw I needed to adjust the oven oriface to control the size of the flame. all the way down or all the way up has no effect on the 6" flame inside of my brand new oven. I believe they understand my situation now. will let you know what the outcome is. Donna Mckinney
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Heartland 5210 stove burner keeps sparking (Oven Repair (including Ranges and Cooktops))
by KUnderhill 6/8/2024 1:40:30 PM(UTC)
GE Stove Control circuit Board (Oven Repair (including Ranges and Cooktops))
by John4321 3/17/2024 10:12:27 AM(UTC)
Control panel for GE Spectra Stove Model # JBP79WB4WW (Appliance Parts)
by janieben@rainbowtel.net 1/22/2024 5:16:12 PM(UTC)
Gremlins in my KitchenAid Stove (Oven Repair (including Ranges and Cooktops))
by Guest 12/19/2023 1:08:12 PM(UTC)
tappan nat. gas cook stove (Oven Repair (including Ranges and Cooktops))
by arkieguide 12/5/2023 1:26:25 PM(UTC)
Bad Stove Element or Bad Switch (Oven Repair (including Ranges and Cooktops))
by BenMjr 9/24/2023 7:08:59 PM(UTC)
GE Glasstop stove burner control knob (Oven Repair (including Ranges and Cooktops))
by Guest 9/17/2023 5:25:35 AM(UTC)
LG Gas Stove fg4331es.fstelga burners will not stay on (Appliance Parts)
by ivel50 6/12/2023 11:15:10 AM(UTC)
Fault code F9 on Maytag stove (Oven Repair (including Ranges and Cooktops))
by Guest 4/17/2023 12:20:08 PM(UTC)
GE Hotpoint Stove Bake Element not working (Oven Repair (including Ranges and Cooktops))
by Guest 3/21/2023 10:17:36 AM(UTC)
Whirlpool Stove working but both heating elements are not (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 1:06:16 PM(UTC)
Electrolux Gas stove igniter (Oven Repair (including Ranges and Cooktops))
by Guest 2/10/2023 10:22:25 AM(UTC)
Frigidaire FES365ECA Stove baking elements will not turn on. (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2023 9:08:26 AM(UTC)
Electrolux gas stove parts (Oven Repair (including Ranges and Cooktops))
by becky97060 12/13/2022 11:00:54 AM(UTC)
