Brand new stove voided the warrenty when i installed my own orfices for propain only thing wrong is the stove is putting off 6" flames. No matter which way i turn the nut left or right, less gas or more gas i still get 6" flames i think I have a faulty factury defect they want 80.00 to come look see. no one will give me low down on if that is the only adjustment for oven flame control all other orfices are fine regulater has been reversed open side toward reg. and burner ports all working fine. please help.
How did you convert the range, which parts you replaced and what are the part numbers?
converted from natural to Lp, changed regulator by turning hub around so that the solid end is toward the regulator. used L.P. conversion kit ESPN:316243723 /Mueller p/n:LP3755BW. I have finally gotten a responce from the dealership. They are going to replace the oven spud/pin assembly ??? . tried to tell me I stripped the thread or I punched the hole bigger by raising the sleeve too high. didnt fly since i never touched the oven oriface at all before i fired it up to cook my biscuits, and the flames put a camp fire to shame. I comitted the cardinal sin of not reading my manual cover to cover untill I saw there was a problem. Then I saw I needed to adjust the oven oriface to control the size of the flame. all the way down or all the way up has no effect on the 6" flame inside of my brand new oven. I believe they understand my situation now. will let you know what the outcome is. Donna Mckinney
