cottonslurpy
#1 Posted : Monday, January 28, 2008 8:14:10 PM(UTC)
cottonslurpy
GE - TBX18CILBQRWW
Freezer on top of single door.
What led to the problem?
Fridge door was left open overnight on accident. Approximately 8 hours. Next morning it would no longer cool. Freezer completely defrosted over the course of the rest of the day.
What have I done?
I've left it unplugged for 24 hrs, then plugged it back in and left it for 24 hours. Still wont cool.
I've left it unplugged for 4 days. Plugged it in and left it for 24hrs. Still wont cool.
Cleaned the coils underneath, of all dust(vaccuum/dust mop). Air can to the back fan and wiring harness.
What I know?
The fan in the lower back, next to the compressor works.
Air blows(flows) into the fridge and also in the freezer section, seemingly unrestricted.
No leaks.
The door/light switch still works: the light shuts off when pressed.
I hear clicking approximately every minute or so, as if something is starting or stopping.
Im not 100% sure on how to tell if the compressor is on or not.
If anyone can lead me in the right direction or bring me closer to a solution or what to pull out and test for functionality, I would greatly appreciate it.
#2 Posted : Tuesday, January 29, 2008 1:38:29 PM(UTC)
Most likely the problem with your fridge caused by the compressor which can not start (clicking noise).
If the fridge is less then 5 years old - the compressor could be under the manufacturer warranty.
If the fridge is not under the warranty, you can:
1. Use a special hard start kit which can help to fix the problem. The success rate is about 65%. It comes with the installation instructions and cost less than $26.00.
2. Replace the compressor. It should be done by a certified technician and will cost you 500 to 600 bucks.
3. Buy a new fridge.
- The part number for the hard start kit is AP3539948
Here are the break down diagrams for the GE refrigerator Model TBX18CIBQRWW
Bought refrigerator wont cool and i smell freon leaking. (Refrigerator & Freezer Repair)
by Tressa1 3/23/2012 6:15:11 AM(UTC)
Refrigerator wont cool (Refrigerator & Freezer Repair)
by Sinchak59 5/15/2011 12:49:56 PM(UTC)
