I have a 5 year old GE Profile SS dishwasher model number PDW9980N00SS. It's worked well for the last five years but this morning I noticed the bottom of the ss tub was full of water. Tried running it again and the same thing. I removed the lower wash arm as I read in a fe other threads but still no luck. Do I need to pull the unit out to access the sump?
Thanks for any help...
Here are your parts Parts for GE PDW9980N00SS Dishwasher - AppliancePartsPros.comYou can click on a part's picture or description in the listing and often a new page will open with a Q&A section that may help. Try The Coarse Filter (Item 502 in the Motor-pump Mechanism section), that should get you to the sump. |
THIS FORUM IS DEAD!!!!!!! |
