gdicio
#1 Posted : Friday, November 9, 2012 11:06:10 AM(UTC)
gdicio
I have a 5 year old GE Profile SS dishwasher model number PDW9980N00SS. It's worked well for the last five years but this morning I noticed the bottom of the ss tub was full of water. Tried running it again and the same thing. I removed the lower wash arm as I read in a fe other threads but still no luck. Do I need to pull the unit out to access the sump?
Thanks for any help...
#2 Posted : Saturday, November 10, 2012 2:01:58 AM(UTC)
Parts for GE PDW9980N00SS Dishwasher - AppliancePartsPros.com
You can click on a part's picture or description in the listing and often a new page will open with a Q&A section that may help.
Try The Coarse Filter (Item 502 in the Motor-pump Mechanism section), that should get you to the sump.
Frigidaire Dishwasher / Water won't drain (Dishwasher Repair)
by ruzquiano 8/27/2014 11:29:59 AM(UTC)
Spin cycle does not start and water won't drain. (Washer Repair)
by civictuner95 7/10/2013 4:16:20 AM(UTC)
Kenmore dishwasher water won't drain (Dishwasher Repair)
by Cujimmy 9/6/2012 8:04:30 PM(UTC)
No final cycle water won't drain (Washer Repair)
by ajones6831 5/17/2011 10:32:21 AM(UTC)
by ajones6831 5/17/2011 10:18:52 AM(UTC)
Water Won't Drain (Washer Repair)
by Lester3 12/16/2010 1:44:38 PM(UTC)
Water won't drain in dishwasher (Dishwasher Repair)
by elkstu 7/30/2010 10:12:32 AM(UTC)
GE Washer water won't drain (Washer Repair)
by nzbarzh 6/30/2010 3:07:02 PM(UTC)
Water won't drain from Rinse cycle (Dishwasher Repair)
by willowj47 6/16/2010 8:07:56 AM(UTC)
Water won't drain completely resulting in rancid smell (Dishwasher Repair)
by cmccloskey79 11/30/2009 12:40:01 PM(UTC)
by ussharryae21 11/3/2009 5:58:59 AM(UTC)
Water won't drain, no power! (Washer Repair)
by longleggedfirecracker 9/12/2009 2:00:03 PM(UTC)
All Water won't Drain (Dishwasher Repair)
by CanuckDuck 8/11/2009 6:17:09 AM(UTC)
no spin, washer water won't drain (Washer Repair)
by kabi54 7/17/2009 10:32:12 AM(UTC)
Kemore 90 series Water won't drain! (Washer Repair)
by eshn7 6/14/2009 6:45:49 PM(UTC)
