allenphelps
#1 Posted : Tuesday, October 30, 2012 3:06:05 PM(UTC)
allenphelps
My ice auger motor will not run on my Whirlpool ED5VHGXML13 side-by-side. How do I test the motor? I am proficient with a multi-meter. I just need to know what to check for and on which pins.
#2 Posted : Wednesday, October 31, 2012 4:17:56 AM(UTC)
If the motor has 120 volts across it and will not rotate then it is toast.
File Attachment(s):
ED5VHG.pdf (575kb) downloaded 61 time(s).
