My ice auger motor will not run on my Whirlpool ED5VHGXML13 side-by-side. How do I test the motor? I am proficient with a multi-meter. I just need to know what to check for and on which pins.
See the attachment for the tech sheet. If the motor has 120 volts across it and will not rotate then it is toast. |
THIS FORUM IS DEAD!!!!!!! |
