Ooltewah
#1 Posted : Saturday, October 13, 2012 12:17:32 PM(UTC)
Ooltewah
GE front load washer leaking water at the back of the drum. I have taken the service panel off and checked the drain and there does not seem to be any clogs. I shined a light and watched as it went through a rinse and spin cycle and could see water dripping at the rear of the washer on the inside. Any suggestions as to what may be causing this?
sidfink43
#2 Posted : Tuesday, October 16, 2012 4:35:45 PM(UTC)
sidfink43
Hard to say without being there. Run it with the back off and see if you can locate the problem.
appliance dude
#3 Posted : Monday, October 22, 2012 5:30:57 PM(UTC)
appliance dude
Check to see if it is coming from behind the pulley.
