AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE front load washer leaking water at the back of the drum.
GE front load washer leaking water at the back of the drum. I have taken the service panel off and checked the drain and there does not seem to be any clogs. I shined a light and watched as it went through a rinse and spin cycle and could see water dripping at the rear of the washer on the inside. Any suggestions as to what may be causing this?
Hard to say without being there. Run it with the back off and see if you can locate the problem.
Check to see if it is coming from behind the pulley.
Washer Repair
