I had a latch locking problem and I sprayed contact cleaner. the door did lock and started the cycle....but it did not run. First fault was F22 than there was a second fault F29. I would like to know how to unlock the electrical door latch. Door wil not open even after being unpluged. Thanks don
Groups: APP Team
Hi.
Unplug the washer. Remove the toe panel. At the bottom of the door latch there is the plastic ring, pull it down to unlatch the door.
Simon.
