We relocated our Jenn-Air dishwasher over the weekend and after the move, it will no longer power-on. It was working just fine before we moved it and after we re-installed it, it initially lit up the "Rinse Only" button but nothing else would work and the unit never actually began the rinse cycle. I flipped the breaker on and off and since then nothing will power on.
I double checked the power to the unit and the power is working fine so the issue definitely seems to be with the dishwasher. I've double checked all the wires I can see underneath the dishwasher and I see no obvious issues. I even rechecked the main leads to ensure they were getting good contact with the power lines.
I'm worried that perhaps when I was disconnecting the unit originally I may have caused an issue when I turned the dishwasher upside down? Any help would be very greatly appreciated. Thank you so much for your time!
Groups: APP Team
Thanks so much for responding, Simon. I'll do that! :)
Groups: APP Team
This fixed it! The control board had gotten wet so I disassembled it and let it dry out for a few hours like you recommended. After putting it all back together it's working great again. Thank you so much!!! :D
Groups: APP Team
