hogunner
#1 Posted : Friday, October 5, 2012 6:04:32 AM(UTC)
hogunner
We relocated our Jenn-Air dishwasher over the weekend and after the move, it will no longer power-on. It was working just fine before we moved it and after we re-installed it, it initially lit up the "Rinse Only" button but nothing else would work and the unit never actually began the rinse cycle. I flipped the breaker on and off and since then nothing will power on.
I double checked the power to the unit and the power is working fine so the issue definitely seems to be with the dishwasher. I've double checked all the wires I can see underneath the dishwasher and I see no obvious issues. I even rechecked the main leads to ensure they were getting good contact with the power lines.
I'm worried that perhaps when I was disconnecting the unit originally I may have caused an issue when I turned the dishwasher upside down? Any help would be very greatly appreciated. Thank you so much for your time!
Simon / APP Team
#2 Posted : Friday, October 5, 2012 11:22:52 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Probably some water got inside the control panel and the touch pad and control board got wet. Take it apart and dry.
You may get lucky. If not - replace the control panel first.
Remember-you may return all unused parts back to APP even installed ones.
Here are the breakdown diagrams and Replacement parts for Jenn-Air JDB1250AWS DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Post the results.
Simon.
hogunner
#3 Posted : Friday, October 5, 2012 11:45:40 AM(UTC)
hogunner
Thanks so much for responding, Simon. I'll do that! :)
Simon / APP Team
#4 Posted : Friday, October 5, 2012 12:01:45 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
hogunner
#5 Posted : Friday, October 5, 2012 8:35:41 PM(UTC)
hogunner
This fixed it! The control board had gotten wet so I disassembled it and let it dry out for a few hours like you recommended. After putting it all back together it's working great again. Thank you so much!!! :D
Simon / APP Team
#6 Posted : Monday, October 8, 2012 8:42:44 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
