Everything seems to be working properly but the clothes are not drying - it takes several cycles to get a load done. What should we look at first, second, etc. to fix.
Here are your parts Replacement parts for GE DVL223EB1WW | AppliancePartsPros.comOften this is just a dirty/malfuntioning vent system. Check and clean it. If it is a royal pain to do you may want to run the♦ following test first. Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems. |
THIS FORUM IS DEAD!!!!!!! |
