poppy518
#1 Posted : Tuesday, October 2, 2012 8:24:11 AM(UTC)
poppy518
When this washer goes into any spin cycles it virbates and shakes badley. I have tried Hi, Med, and low speeds and it does the same. Load can be full or half and does the same. I live in a dbl wide mobile home and at times you can feel it thru the entire house. Do I need to call someone to service this or is this normal?
sidfink43
#2 Posted : Thursday, October 4, 2012 3:47:12 PM(UTC)
sidfink43
No it is not normal. Before you call a repair person take off the back and see if you can see a broken strut support.
Guest (4)
Frigidaire front load washer vibration (Washer Repair)
by kbrutschy 12/21/2011 11:03:46 AM(UTC)
