frigadare
#1 Posted : Tuesday, October 2, 2012 7:58:47 AM(UTC)
frigadare
The freezer is slightly cooler than the refrigerator. No Ice. was getting cooler until moved to another location. Now the frig is 70 and the freezer is about 63. I changed the defrost thermosat and reset to 4 - 4 on the cold settings. Still not getting cold and no ice or frost showing on down below.
Any help is appreciated.
Simon / APP Team
#2 Posted : Tuesday, October 2, 2012 12:05:10 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if the compressor is running. Do you hear hum and click from it? Remove the starting devise and shake it. If it rattles you need to replace it.
But before doing it check if the three compressor's pins has continuity between them and no continuity to the ground.
The relay/overload Part number: 2188830
Post the results.
Simon.
freezer and frig not cooling???? (Refrigerator & Freezer Repair)
by pmase123 7/23/2011 7:18:56 AM(UTC)
Whirlpool freezer and frig not cooling (Refrigerator & Freezer Repair)
by KWVB 6/3/2011 7:13:07 PM(UTC)
Freezer and Frig not cooling (Refrigerator & Freezer Repair)
by Vince S. 5/13/2009 3:59:26 PM(UTC)
