My side by side is not cooling. The compressor does not run. The evaporator fan does not run. Where do I start?
Thanks for your advice. I removed the relay and capacitor. Seems to be a bit oily and some oil underneath. The capacitor terminals that plug into compressor are scorched and maybe even melted some? Does this mean that the compressor is no good also? Thanks. ---Vince
