At the end of the rinse cycle, the washer does not go into spin and the timer indicator light goes blank . It does not display an error code.
I can not get your model to come up, can you check the model number.
If this is a front load washer the likely suspect is your motor control/speed control board.
GLTF 2940 ES is the model number. I too think that it is the board because it doesn't give an error code as it does when the coin catcher is full.
Use this service manual to see if you can put it into troubleshooting mode. http://frigidaireservicetips.co...rizontalAxisWasherSM.pdfYou have a control board and a motor/speed control board and since they are expensive you want to make sure you are replacing the right one. Since it will go through the wash cycle I suspect it is the motor/speed board.
