christo83
#1 Posted : Sunday, September 23, 2012 3:48:55 PM(UTC)
christo83
A couple months after replacing rear bearing and seals we now have the moldy smell problem that these machines are pron to but never had before. I didn't replace the gasket between the barrel half's but there no leaks there. The rubber boot looked good and is glued back into place on the door face. The only thing I can see that maybe causing an issue is there's still water in the pump boot and the water exit line at the end of the spin out. Maybe a pump issue?
#2 Posted : Monday, September 24, 2012 5:23:10 PM(UTC)
It can be. Check the drain pump and the hoses.
christo83
#3 Posted : Monday, September 24, 2012 6:16:29 PM(UTC)
christo83
Thanks, I'm guessing there should be little if no water left in the boot off the pump and the exit water line. I have water in both.
#4 Posted : Tuesday, September 25, 2012 12:42:55 PM(UTC)
It does not drain out completely because water works as a lubricant for the pump impeller.
