joni08
#1 Posted : Sunday, January 27, 2008 1:47:16 PM(UTC)
joni08
read blogs of others with same problem checked valves no frozen lines you say if water fills im when wires switched to replace im can you just replace something in unit?
#2 Posted : Monday, January 28, 2008 10:07:13 AM(UTC)
Does the ice maker motor cycle?
If it does, then it could be the water valve actuating switch inside the ice maker.
If it does not, then the ice maker has to be replaced.
- The part number for the micro-switch is AP3960700
- The part number for the ice maker is AP3160597
Here are the break down diagrams for the Frigidaire refrigerator Model FRS20ZGGB1
Whirlpool Icemaker Not Filling With Water (Refrigerator & Freezer Repair)
by jgibby65 1/28/2013 2:13:27 PM(UTC)
icemaker not filling with water (Refrigerator & Freezer Repair)
by deli63 2/8/2012 5:10:25 PM(UTC)
Icemaker not filling with water (Refrigerator & Freezer Repair)
by wester2009 5/26/2009 10:51:51 AM(UTC)
by grtspcs 4/21/2009 9:24:10 AM(UTC)
