jared parsons
#1 Posted : Friday, September 14, 2012 6:33:39 AM(UTC)
jared parsons
I have an admiral washer that stopped draining and cycling,but the motor humbs.
Simon / APP Team
#2 Posted : Friday, September 14, 2012 5:29:10 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Disassemble the washer and take the drain pump off the motor. See if it's jammed. disconnect the motor from the transmission lay it on the ground and start without the load.
Check the start capacitor Part number: 8572717
Use the video clip for the instructions Part number: 661600
Admiral washer squeaks during agitation (Washer Repair)
by kukayaker 10/10/2014 10:47:17 AM(UTC)
Admiral Washer Machine Water Temp Not Working Correctly (Washer Repair)
by CRAIG1978 7/26/2014 11:08:17 AM(UTC)
Admiral washer drains, but won't spin in wash cycle (Washer Repair)
by WJG 7/19/2014 2:32:36 PM(UTC)
Admiral washer just fills (Washer Repair)
by 73buick225 3/2/2014 3:26:31 PM(UTC)
Admiral washer pls help (Washer Repair)
by nomifish07@aol.com 1/25/2014 12:46:17 PM(UTC)
Admiral washer: Cold water only on warm setting (Washer Repair)
by divemasterjt 11/20/2013 7:18:09 PM(UTC)
Admiral Washer: howling, spinning, smoking... (Washer Repair)
by Noobzilla 7/17/2013 9:03:46 PM(UTC)
Admiral Washer Spin Cycle problem (Washer Repair)
by nckomorowski 10/21/2012 8:15:37 AM(UTC)
admiral washer (Washer Repair)
by tvanloon43 7/12/2012 7:17:42 AM(UTC)
Admiral washer leak (Washer Repair)
by llimer 3/20/2012 6:10:55 AM(UTC)
Admiral washer agitates during spin cycle (Washer Repair)
by Trenchfoe 3/4/2012 6:55:13 AM(UTC)
Admiral washer agitates but wont drain. (Washer Repair)
by smitty225 2/28/2012 12:04:17 AM(UTC)
Admiral washer wont fill (Washer Repair)
by jay1437 1/15/2012 1:35:43 PM(UTC)
Admiral washer machine (Washer Repair)
by 01queenie01 5/8/2011 9:14:49 AM(UTC)
Admiral Washer won't spin (Washer Repair)
by Kimbobwae 4/3/2011 6:11:58 PM(UTC)
