adelavan
#1 Posted : Thursday, September 6, 2012 9:22:48 AM(UTC)
adelavan
Yesterday my dryer tripped a main circuit to home after my daughter started the dryer and now the panel does not light up or start. I reset the breaker to the home and there is power coming out of the outlet but no luck.
A few months ago I smelled burnt wire when I was drying a comforter and I've smelled it in the past and thought maybe the smell was from overloading the machine but it's meant to hold a comforter. I thought there was strain on belt.
The manual says it could be Thermal Limiter
Part Number: PS755806
But why does the control panel not light up?
Machine get lots of use and is 5-7 years
Simon / APP Team
#2 Posted : Thursday, September 6, 2012 10:11:08 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You should start with checking the thermal limiter
Part number: WE04X10094
Located on daigr#1 #1236.
Check if there is continuity at the limiter.
No continuity - replace it.
Here are the breakdown diagrams and http://www.appliancepartspros.c...el.aspx?model_id=5219576
Post the results.
Simon.
