My washer has started making a sort of grinding noise. I am wondering if it is the pump. How do I get to the pump to see if it is clogged? I think that there is a panel on the front under the drum, but how do I get this off? Thanks so much!
You can click on your model number to see exploded views of your machine.
The panel should come off if you take out the screws that hold it on. They are hard to see sometimes.
