AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer making grinding noise on rinse and spin cycle
My washer is making a grinding noise when its on the spin/rinse cycle. dont really have a lot of money to replace as we just put in new carpet and tile in the house. so would be nice if it was an easy fix. one fourm said it could be a drain pump bearing or the thrust bearing but that was for a whole another brand. dont know if this brand and model has those? please help!!!
Remove the cabinet and check the motor drive coupling (#13 at the diagram). There is the instructional video under the part picture. - The motor drive coupling Part number: 285753A
Washer Repair
