This dryer will not start/run. I have checked all thermal / limit switches, and door switch. All have continuity. I have the proper voltage to the dryer. How do you check the Push to Start relay? I have continuity to two wires of the three. Can you jump any of the wires to the Push to Start to get it to run. I can hear the timer motor running Thank you for any help/information you may privide.
Groups: APP Team
