maintenancetech
#1 Posted : Tuesday, August 28, 2012 5:46:37 AM(UTC)
maintenancetech
This dryer will not start/run. I have checked all thermal / limit switches,
and door switch. All have continuity. I have the proper voltage to the dryer. How do you check the Push to Start relay? I have continuity to two wires of the three. Can you jump any of the wires to the Push to Start to get it to run. I can hear the timer motor running
Thank you for any help/information you may privide.
Simon / APP Team
#2 Posted : Tuesday, August 28, 2012 2:55:15 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you are sure that thermal fuse is OK first with timer set for heat jump the two blue wires at the start switch.
If that doesn't work jump the T-W at the timer.
Here are the breakdown diagrams and Replacement parts for Whirlpool LER8620PW0 29"ELECTRIC DRYER | AppliancePartsPros.com
Post the results.
Simon.
