moved refrigerator from old office to house. During move the refrigerator was laid on it's side. Let sit for about a week and then started up. Freezer worked great, but refrigerator was not cooling. Pulled out from wall to inspect unit underneath. Unit was covered in dust and hair.. we purchased used several years ago, but anyway unit compressor quit running. Inspected further and condenser fan not running as it seems to be worn out. Compressor starts but shuts off after few seconds. Questions are as follows:
1. have tried to find manual on model number above with no luck. 2. Can not remove freezer fan housing to determine if fan is not running fast enough.... without no manual hot to get off???? 3. Condenser fan model number is hard to find, and would I assume this to be the issue.
can not find anything on model number listed above..
any help would be helpful....
Check the model #, also, if the compressor is very hot, put a portable fan to cool the condenser and compressor.
Model is HMG 21146 Can not find anything on this model....
