OleRon
#1 Posted : Monday, September 21, 2009 8:35:00 AM(UTC)
OleRon
The agitator barely works - clothes spins fine. I think I need an agitator repair kit but I don't know how to remove the agitator.
sidfink43
#2 Posted : Monday, September 21, 2009 5:16:32 PM(UTC)
sidfink43
Click on your model number and you will see an exploded diagram of your machine.
To remove the agitator pull of the cap which will expose a 7/16" bolt. Take it out and the top will come off. You can then lift the agitator off.
Here is your repair kit
Part number: AP3138838
OleRon
#3 Posted : Tuesday, September 22, 2009 7:58:30 AM(UTC)
OleRon
:) :) :) Thanks sidfink43 - removed agitator, found agitator clutch dogs badly worn. Ordered repair kit. You are the man!
sidfink43
#4 Posted : Tuesday, September 22, 2009 8:31:07 AM(UTC)
sidfink43
This is great, you do all the work and we get the praise
Thanks for updating us, good luck with the repair.
How to remove agitator on GE GTWP1800D0WW (Washer Repair)
by CCC1620 1/24/2015 10:40:44 AM(UTC)
How to remove agitator from GE washer (Washer Repair)
by jthrrt 1/1/2013 4:43:23 PM(UTC)
How to remove agitator (Washer Repair)
by just_chillin38 12/27/2012 12:12:34 PM(UTC)
How to Remove Agitator (Washer Repair)
by this_is_nascar 6/11/2012 8:32:07 AM(UTC)
how to remove Agitator on Frigidaire (Washer Repair)
by vinster 10/4/2011 11:46:19 AM(UTC)
How to remove agitator assembly (Washer Repair)
by BylerB 3/6/2010 5:41:41 AM(UTC)
by salem70123 10/5/2009 6:42:02 PM(UTC)
How to remove agitator assy (Washer Repair)
by ddjclark 6/3/2009 4:34:25 PM(UTC)
How to remove agitator on newer GE washer (Washer Repair)
by lba 12/29/2008 8:26:41 AM(UTC)
How to remove agitator? (Washer Repair)
by Dobbsey 10/15/2008 1:03:15 PM(UTC)
