The agitator barely works - clothes spins fine. I think I need an agitator repair kit but I don't know how to remove the agitator.
Click on your model number and you will see an exploded diagram of your machine. To remove the agitator pull of the cap which will expose a 7/16" bolt. Take it out and the top will come off. You can then lift the agitator off. Here is your repair kit Part number: AP3138838
:) :) :) Thanks sidfink43 - removed agitator, found agitator clutch dogs badly worn. Ordered repair kit. You are the man!
This is great, you do all the work and we get the praise
Thanks for updating us, good luck with the repair.
