AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu
Maytag washer Model Number MAV6000AWW Problem: Filling and agitation are fine. Most water is drained out, but clothes (only one towel) are very wet after spin cycle. After replacing new pump and new belt, the problem was the same. Anything else can I do? Pleas advise me. Thank you very much. Adam
There can only be two reasons why the clothes are too wet, the spin is to weak or the water is not being pumped out.
Try to determine if the spin is at appropriate speed. If so, then since you have replaced the pump try to determine if there is an obstruction somewhere in the drain system, either inside the washer or in the drain pipe outside the washer.
Originally Posted by: sidfink43  There can only be two reasons why the clothes are too wet, the spin is to weak or the water is not being pumped out.
Try to determine if the spin is at appropriate speed. If so, then since you have replaced the pump try to determine if there is an obstruction somewhere in the drain system, either inside the washer or in the drain pipe outside the washer. I have completely checked inside the washer and in the drain pipe outside the washer and id not find any obstruction in the drain system. So maybe the spin is not at appropriate speed. How to check whether the spin is at appropriate speed or not? If indeed the spin is NOT at appropriate speed, how to fix it? Thank you. Adam
I am not sure how you check the speed other than observe it and see if it seems about right. Here is the likely repair parts. Part number: AP4009132
Washer Repair
