My ice maker works fine but will shut off either when the arm is raised or when the bucket is full of ice. I have to pull the bucket out & empty it periodically.
Originally Posted by: Mopar75  My ice maker works fine but will shut off either when the arm is raised or when the bucket is full of ice. I have to pull the bucket out & empty it periodically. Based on the way you have this worded its working fine. Its normal to once in awhile to have to get rid of the old ice.
Glen, I apologize I made a typo...The ice maker WILL NOT shut off when the arm is raised either by doing it manually or if the ice gets high enough to push it up. Again I apologize.. Russ
Hi Glen, I got the motor module for my Whirlpool refrigerator & am trying to replace the old one. I removed the cover & the mounting screws but the module itself won't come off. I didn't want to force it thinking there may be something else I have missed. Could you shed any light on this?
Thanks, Russ
