alfonso m
#1 Posted : Saturday, August 18, 2012 2:18:19 PM(UTC)
alfonso m
Serial Number is A9147617EC
My unit wont allow me to turn on via touch pad on front
seems half the buttons work on one side the others dont
i dont know if i need to replace the main board or the touch pad or the r-11 and r-6
im not sure about the r-11 and r-6 i read these on line and said if one fails you need to replace both as these will cause the touch pad to fail
also is there any way to bypass anything so i may do laundry while i am waiting for parts from you
let me know asap
Al
euroal13@yahoo.com
alfonso m
#2 Posted : Saturday, August 18, 2012 2:20:40 PM(UTC)
alfonso m
let me know asap
Al
euroal13@yahoo.com
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 10/26/2018 8:36:20 AM(UTC)
Maytag neptune washer logic board (Washer Repair)
by Busch58 1/10/2018 1:09:35 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
Maytag Neptune Washer Clutch Replacement (Washer Repair)
by helplessm355 4/16/2015 5:22:16 PM(UTC)
maytag neptune washer MAH9700AWM wont spin (Washer Repair)
by biztyke 4/9/2015 11:19:06 PM(UTC)
Maytag Neptune Washer Shuts off After Water Fill (Washer Repair)
by kluskc 12/7/2013 9:15:13 PM(UTC)
Maytag Neptune Washer will not spin (Washer Repair)
by BStevens82 5/22/2013 9:55:09 AM(UTC)
Maytag Neptune washer code uc (Washer Repair)
by Jef_R 3/18/2013 3:19:45 PM(UTC)
Maytag Neptune Washer shuts off (Washer Repair)
by HHB 12/5/2012 8:23:26 PM(UTC)
Maytag Neptune Washer Spin Cycle Noise (Washer Repair)
by jayjaysin 8/19/2012 6:14:50 AM(UTC)
Maytag Neptune washer & dryer reputation (Washer Repair)
by LLLN 8/12/2012 8:26:24 AM(UTC)
by LLLN 8/12/2012 8:25:00 AM(UTC)
Maytag Neptune Washer - cold won't fill (Washer Repair)
by sandylouwhoo 3/30/2012 8:00:23 AM(UTC)
Maytag neptune washer (Washer Repair)
by sideloc50 2/29/2012 1:40:24 PM(UTC)
