My Kenmore HE3 Frontload washer stops and shows F and H codes in the countdown box. I have to pause and restart several times throughout a wash cycle. Once it gets past the stop at 24 minutes left it usually finishes the cycle without stopping.
What is the complete model number of the washer?
Kenmore HE3 Model 11045862400, Ser CSS2913334, type 199
Originally Posted by: DebCarrigan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Kenmore HE3 Model 11045862400, Ser CSS2913334, type 199 Not sure if this was sent the first time as internet went down just then.
Perform the troubleshooting as described in the attached tech sheet for this error code. Post the results. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Perform the troubleshooting as described in the attached tech sheet for this error code. Post the results.
Gene. How do we "verify pressure switch operation" and "verify flow meter operation" and "verify CCU operation" All other checks seem to be functioning.
Originally Posted by: DebCarrigan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How do we "verify pressure switch operation" and "verify flow meter operation" and "verify CCU operation" All other checks seem to be functioning. "Verify flow meter operation" was followed by "...by blowing air through the part and measuring resistance". Did you run the diagnostic test? What about water in the washer? Gene.
