I am renting a house that has a Kitchenaid refrigerator model #KSRT25CRBL01. The refrigerator works flawlessly. The ice maker will make ice but it fails to dispense the ice. The water dispensor works great. The ice dispensor door will not open. If I force it open the ice will dispense normally. The motor and auger work. There is also a red light flashing in the freezer compartment next to the ice maker on/ off switch. Does anyone have any idea how i can check this out.
Hi Bryan, Remove the ice door motor and check it as described in the attached files. Post the results. - The ice door motor Part number: W10184813
Gene, Thanks for the information. I removed the dispenser cover and removed the connector P5 on the core board. I checked the resistance between Pin 1 and pins 2, 3, 5, and 6. All of the readings were between the 45 and 55 ohms. I didn't actually remove the motor will that make a difference? Where can I check next if not. Thanks, Bryan
Bryan, If there is nothing wrong with the motor then the problem is a bad dispenser control board. - The dispenser control board Part number: 2303843
Thanks,
I will let the owner know. I appreciate your time.
Bryan
Motor had no voltage, replaced control board and still no ice. Now what?
What is the complete model number of the refrigerator?
Did you do any troubleshooting before you replaced the motor?
