the water dispenser is constantly dripping. Had to turn off water supply. What part is needed to fix this and is it possible to self-repair?
I would replace the water inlet valve (on the back of the refrigerator) first. This part is not too difficult to replace if you know how to handle a simple tools. Do not forget to unplug the refrigerator and turn off the water to the refrigerator. - The water inlet valve Part number: WR57X10051
Originally Posted by: Gene  I would replace the water inlet valve (on the back of the refrigerator) first. This part is not too difficult to replace if you know how to handle a simple tools. Do not forget to unplug the refrigerator and turn off the water to the refrigerator. - The water inlet valve Part number: WR57X10051
Thank you Gene for the info. I will order the part and do that. Have a blessed day. acreed59
