Vizlaboy
#1 Posted : Tuesday, August 14, 2012 9:47:23 AM(UTC)
Vizlaboy
I get a large bulbus ice buildup just above the evaporator blades just under the fan motor. It takes a few weeks for the ice to buildup but eventually the ice gets so big that it pushes the rear of the freezer out and makes a noise.
I have attached two pictures (one before, one after). Why is this happening? The schematic diagram doesn't indicate this part. What needs to be replaced?
I assume the heater is functioning since the blades are frost free and the sides show some signs of melting / burn.
Any thoughts? See attached images.
Vizlaboy attached the following image(s):
#2 Posted : Tuesday, August 14, 2012 5:00:17 PM(UTC)
There is a problem with the sealed system. It can be low on Freon or there is a restriction in the capillary tube. It needs more tests which have to be done by a certified refrigeration tech. Such repairs could be pretty expensive.
