havebikewilltravel
#1 Posted : Tuesday, August 7, 2012 1:04:36 PM(UTC)
havebikewilltravel
Unit stopped making ice. In the section on running the unit through its cleaning cycle, the user guide states, "After the cleaning cycle is complete....if cleaning solution drains from the water pan, you should run the clean cycle again." Does this imply the drain pan should be EMPTY after the cleaning cycle? :confused: And if the drain pan is not empty (as in, brimming full to overflow), does that tell me something about what part is malfunctioning?
I can find no information on the internet about these stand-alone ice makers. Everything seems to be about refrigerator ice makers. (I notice you don't even have a topic section for this type of appliance.)
#2 Posted : Tuesday, August 7, 2012 2:45:55 PM(UTC)
Hope the attached manuals will help.
Here are the breakdown diagrams and Replacement parts for Whirlpool GI1500XHS7 ICE CUBE MAKER | AppliancePartsPros.com
File Attachment(s):
Ice Maker Intro.pdf (59kb) downloaded 12 time(s).
Ice Maker Sect 2 - Theory of operation.pdf (89kb) downloaded 15 time(s).
Ice Maker Sect 4 - Troubleshooting.pdf (11kb) downloaded 29 time(s).
Ice Maker Sect 5 - Diagrams and more.pdf (150kb) downloaded 17 time(s).
