Papa_Blowfish
#1 Posted : Friday, August 3, 2012 10:52:46 AM(UTC)
Papa_Blowfish
This is a top frig, bottom freezer model with digital read outs. The frig has been running too cold, freezing eggs for example. I DID also have a small ice build up in the freezer. The light switch had just a tad of ice on it so it wouldn't turn on the light, but so little that moving the switch by had removed the ice.
I removed the freezer back, and there was a bit of ice on the copper line right where it goes into the condenser. I melted it with a hair dryer.
I have verified the digital read out with a freezer thermometer. It basically matches the read out at 0 for freezer and 39 for frig.
I have replaced the dampener 2 times. Both times it was working correctly, but making a grinding noise. It still appears to be working correctly. And the unit does not seem to be running continuously. From reading other posts, it seems I may need to change the thermistor. My concern is with the digital read out showing the correct temp, could the thermistor be bad?
Also, do I change the freezer or the refrigerator thermistor?
Finally, can someone tell me how to access the self diagnostics? I haven't been able to find this info for my model. Or is there a link available to a factory manual?
THANK YOU AS ALWAYS. This board is AWESOME.
Papa_Blowfish
#2 Posted : Sunday, August 5, 2012 8:42:49 AM(UTC)
Papa_Blowfish
Anyone? Help, please. Thank you!
#3 Posted: : Monday, August 6, 2012 3:15:29 AM(UTC)
I would replace the fridg thermistor and see what happens. I usually use a laser thermometer to check the freezer output temperature. If temperature too low, it can cause problems.
Papa_Blowfish
#4 Posted : Monday, August 6, 2012 7:24:42 AM(UTC)
Papa_Blowfish
I'll have to find my laser. What temp should the freezer output be around?
Will order the frig thermistor today. THANK YOU!!
LG (LFX23961ST/01) Refrigerator is too cold (Refrigerator & Freezer Repair)
by newburger90 5/9/2023 7:38:37 AM(UTC)
My refrigerator is too cold . Setting only on 1 (Refrigerator & Freezer Repair)
by Guest 3/25/2021 8:10:41 AM(UTC)
refrigerator is too cold (Refrigerator & Freezer Repair)
by wbgolding 10/5/2010 11:39:25 AM(UTC)
by Ly Collins 8/6/2010 11:40:44 AM(UTC)
