whiztech
#1 Posted : Wednesday, August 1, 2012 7:54:00 PM(UTC)
whiztech
[COLOR="Green"]Hi,
After a thunderstorm my wife tried to use this washer & the display seems fine, but it buzzes and keeps filling with water and will not proceed thru cycles.
Bad Main Control board? Is it worth fixing?
Thanks.[/COLOR]
sidfink43
#2 Posted : Friday, August 3, 2012 4:16:57 PM(UTC)
sidfink43
These are great machines, but the electronics on them are extremely complicated. I would replace it. If you have a low enough deductible on your home owners ins they may pay for part of the cost.
whiztech
#3 Posted : Friday, August 3, 2012 6:59:16 PM(UTC)
whiztech
Since all of the display seems OK - would you replace the "main board" ? Does the 1 year return policy apply if I do?
Also I have a GE side-by-side refrigerator GSS23Q series that keeps freezing up - how hard is it to determine if it is a PCB in the back or a element, or hi limit, etc? Is there a schematic for it? Fan in freezer had been pulsing up & down in speed intermittently for the last year or so prior to that...
I can defrost with a hair dryer & it works for almost a week & freezes solid.
Thanks!
sidfink43
#4 Posted : Saturday, August 4, 2012 4:09:12 AM(UTC)
sidfink43
If you want to try to fix the LG I would replace the main board. Check with APP on their return policy (those of us who reply here are volunteers and not associated with the company)
On the refrigerator I would start with the thermostat, and you can find an exploded view of the fridge by using its model number and the "Find Parts" page.
Good luck.
