lfunder
#1 Posted : Monday, July 30, 2012 11:58:25 AM(UTC)
lfunder
Suddenly the fridge & freezer are not cool enough. The meat still seams to be frozen, but the icecream is mushy. The milk is semi cold.
We also have had problem the last 6 months with very loud noises coming from the fan in the freezer that stops when you open the door
ApplianceJunk
#2 Posted : Monday, July 30, 2012 12:17:21 PM(UTC)
ApplianceJunk
Is the fan in the freezer still running?
Are the condenser coils on the bottom of the refrigerator clean?
lfunder
#3 Posted : Monday, July 30, 2012 12:32:22 PM(UTC)
lfunder
I'm away from the fridge now, had to come from work. I think the fan was still running. where are the condenser coils? on the bottom on the outside of doors??
ApplianceJunk
#4 Posted : Monday, July 30, 2012 12:38:04 PM(UTC)
ApplianceJunk
The condenser coils are located at the back of the refrigerator towards the floor. Once you pull the refrigerator out you will see the access panel. Unplug the refrigerator and remove the access panels. You will see the compressor, fan and coils. The coils collect dust over time and plug up. Then the refrigerator has to work harder to keep things cooling. Could be so plugged up that it just can't cool like it should any more. Coils should be cleaned once a year, twice a year if you have pets.
lfunder
#5 Posted : Tuesday, July 31, 2012 7:59:00 AM(UTC)
lfunder
OK, I cleaned all the coils (yes they were very dirty. Waited overnight and it is still not cold enough.
Any other suggestions?
