AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer wont turn on, bulb stays lit when door closed
Dryer won't turn on. Bulb was burned out, replace, and still stays on with door closed, is this likely a bad door switch, or could it be bad timer?:confused:
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
