Discuss
dryer won't turn on, also light stays on with door closed
 in
Dryer Repair
Dryer won't turn on, also, replace burned bulb, and it stays on with door closed, could this be a bad
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer won't turn on, also light stays on with door closed
  #1 (permalink)
Old 07-24-2012, 05:17 PM
Junior Member
mazw is on a distinguished road
Default dryer won't turn on, also light stays on with door closed
Model Number: LEQ9508PW1   Brand: Whirlpool   Age: 1 - 5 years
Dryer won't turn on, also, replace burned bulb, and it stays on with door closed, could this be a bad door switch, or is it mare likely a bad timer?
Ads By Google
Related Models
Whirlpool LEQ9508PW1 29" ELECTRIC DRYER
Whirlpool LEQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9557KT1 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LEQ9558KT0 RESIDENTIAL DRYER
Whirlpool LEQ9558KT1 RESIDENTIAL DRYER
Whirlpool LEQ9857LG0 RESIDENTIAL DRYER
Whirlpool LEQ9857LG1 29"ELECTRIC DRYER
Whirlpool LEQ9857LW0 RESIDENTIAL DRYER
Whirlpool LEQ9857LW1 29"ELECTRIC DRYER
Whirlpool LEQ9857PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858LG0 RESIDENTIAL DRYER
Whirlpool LEQ9858LG1 29"ELECTRIC DRYER
Whirlpool LEQ9858LW0 RESIDENTIAL DRYER
Whirlpool LEQ9858LW1 29"ELECTRIC DRYER
Whirlpool LEQ9858PG0 29"ELECTRIC DRYER
Whirlpool LEQ9858PG1 29"ELECTRIC DRYER
Whirlpool LEQ9858PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858PW1 29"ELECTRIC DRYER
Whirlpool LEQ9957KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9957KT0 RESIDENTIAL DRYER
Admiral LER1115AAW RANGE- F/S STD ELE
Whirlpool LER2614BW0 ELECTRIC DRYER
Whirlpool LER2614BW1 ELECTRIC DRYER
Whirlpool LER2614BW2 ELECTRIC DRYER
Whirlpool LER2614DW0 ELECTRIC DRYER
Whirlpool LER2614DW1 ELECTRIC DRYER
Whirlpool LER2614EW0 ELECTRIC DRYER
Whirlpool LER2614EW1 ELECTRIC DRYER
Whirlpool LER2614EW2 ELECTRIC DRYER
Whirlpool LER2614JQ0 ELECTRIC DRYER
Whirlpool LER2614JQ1 ELECTRIC DRYER
Whirlpool LER2614JQ2 29"ELECTRIC DRYER
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB RANGE- S/C F/S ELE
Admiral LER3330AAW RANGE- S/C F/S ELE
Admiral LER3330AAZ RANGE- S/C F/S ELE
Whirlpool LER3422AW0 Residential Dryer
Whirlpool LER3424AW0 Residential Dryer
Whirlpool LER3622BN0 COMPACT ELECTRIC DRYER
Whirlpool LER3622BW0 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622HQ0 DRYER
Whirlpool LER3622HQ1 RESIDENTIAL DRYER
Whirlpool LER3622PQ0 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3624BN2 ELECTRIC DRYER
Whirlpool LER3624BN3 ELECTRIC DRYER
Whirlpool LER3624BW0 ELECTRIC DRYER
Whirlpool LER3624BW1 ELECTRIC DRYER
Whirlpool LER3624BW2 ELECTRIC DRYER
Whirlpool LER3624BW3 ELECTRIC DRYER
Whirlpool LER3624DQ0 DRYER
Whirlpool LER3624DQ1 ELECTRIC DRYER
Whirlpool LER3624DQ2 ELECTRIC DRYER
Whirlpool LER3624DZ0 DRYER
Whirlpool LER3624DZ2 ELECTRIC DRYER
Whirlpool LER3624EQ0 LAUNDRY DRYERS
Whirlpool LER3624EQ1 ELECTRIC DRYER
Whirlpool LER3624JQ0 DRYER
Whirlpool LER3624JQ1 RESIDENTIAL DRYER
Whirlpool LER3624JQ2 29" ELECTRIC DRYER
Whirlpool LER3624PQ0 29" ELECTRIC DRYER
Whirlpool LER3624PQ1 29" ELECTRIC DRYER
Whirlpool LER3634EW0 ELECTRIC DRYER
Whirlpool LER3634EW1 DRYERS
Whirlpool LER3634EW2 ELECTRIC DRYER
Whirlpool LER3634JW0 ELECTRIC DRYER
Whirlpool LER3634JW1 RESIDENTIAL DRYER
Admiral LER3725AAC RANGE- S/C F/S ELE
Whirlpool LER4434AN0 ELECTRIC DRYER
Whirlpool LER4434AN1 ELECTRIC DRYER
Whirlpool LER4434AQ0 Residential Dryer
Whirlpool LER4434AQ1 ELECTRIC DRYER
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
  #2 (permalink)
Old 07-25-2012, 01:35 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for Whirlpool LEQ9508PW1 29" ELECTRIC DRYER | AppliancePartsPros.com
Yes it does sound like the door switch (Item 10 in Section 2)is toast.
Before replacing try to actuate it manually.
If does work then maybe only the actuator arm needs reforming.
Sometimes they can get bent.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer wont turn on, bulb stays lit when door closed mazw Dryer Repair 1 07-25-2012 01:36 AM
Dryer quit..light stays on with door closed Sdl101 Dryer Repair 0 05-11-2011 03:22 PM
Light Bulb stays on with door closed. sagemage Refrigerator & Freezer Repair 0 05-05-2010 04:57 PM
dyer door closed but light stays on and dryer willnot run bhender57 Dryer Repair 1 10-17-2009 06:39 AM
Microwave Stays Partially On When Door Is Closed eber91 Microwave Repair 0 04-30-2009 02:08 PM
