where is the spark module and how do i get to it?:confused:
if im not mistaken, this model had it beneath the main top .. sometimes you could access it from behind the range w/ o lifting off the main top ... doubtful, that it is in the lower right corner underneath range ( remove storeage draw to check , mounted to a metal bracket . )
since this stove top is a sealed top, i will assume i have to remove the burners before the top can be lifted off?
yes, absolutely, shouldnt be too dificult, they just unscrew out ( about a 1/4 turn ) then there are screws underneath each burner and there is a wire or two that go to each burner...
