dodgeguy
#1 Posted : Friday, January 25, 2008 12:25:05 AM(UTC)
dodgeguy
where is the spark module and how do i get to it?:confused:
kawfeeman
#2 Posted : Friday, January 25, 2008 4:38:31 AM(UTC)
kawfeeman
if im not mistaken, this model had it beneath the main top .. sometimes you could access it from behind the range w/ o lifting off the main top ... doubtful, that it is in the lower right corner underneath range ( remove storeage draw to check , mounted to a metal bracket . )
dodgeguy
#3 Posted : Friday, January 25, 2008 3:21:19 PM(UTC)
dodgeguy
since this stove top is a sealed top, i will assume i have to remove the burners before the top can be lifted off?
kawfeeman
#4 Posted : Saturday, January 26, 2008 6:25:41 AM(UTC)
kawfeeman
yes, absolutely, shouldnt be too dificult, they just unscrew out ( about a 1/4 turn ) then there are screws underneath each burner and there is a wire or two that go to each burner...
