AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Whirlpool Fridge Top Freezer Icemaker Water will not stop filling Icemaker
Hello,
I have a Whirlpool Fridge Top Freeezer in which a Icemaker was installed and cannot get the water to the ice tray to stop filling. Returned the orginal icemaker and re-installed another and have the same problem water fills the ice tray at a very fast rate and will not stop. Icemaker does make ice correctly, but water flow does not stop to tray. Responses are greatly appreciated.
Sean
Unplug the fridge. If the water does not stop then the fill valve needs replacing. |
THIS FORUM IS DEAD!!!!!!! |
I have similar issue. Procrastinated in hooking up icemaker. Finally did and water won't stop flowing. Did you replace water valve and did that fix it?
