kevin180
#1 Posted : Thursday, September 17, 2009 10:47:51 AM(UTC)
kevin180
replaced even heat electonic control assembly since then will run very hot for two or three loads and cuts of thermal fuse has happen twice
sidfink43
#2 Posted : Sunday, September 20, 2009 10:43:41 AM(UTC)
sidfink43
Open up the dryer and clean out the inside, particularly the blower assembly and related passages. Then thoroughly clean out the vent to the outside.
The primary reason the thermal fuse blows is because of restricted air flow.
SublimeMasterJW
#3 Posted : Sunday, September 20, 2009 11:49:03 AM(UTC)
SublimeMasterJW
I would also go ahead and REMOVE the filter housing and hit the insides with a water hose. Get the sand out of the base of the blower housing too.
#4 Posted : Monday, September 21, 2009 3:40:57 AM(UTC)
Here is some info. They even have a separate section on this wonderful innovation from Whirlpool, see Item 40
http://www.applianceaid.com/whirlpool-dryers.html
