my dishwasher starts but stops after 1-2 minutes. I was told to try cleaning drain. I was able to remove white cage in bottom of washer but cannot get the grey part out. should i be able to remove this and clean? if so, how do i get it out to clean it?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: lpiatchek my dishwasher starts but stops after 1-2 minutes. I was told to try cleaning drain. I was able to remove white cage in bottom of washer but cannot get the grey part out. should i be able to remove this and clean? if so, how do i get it out to clean it? what was the problem with your d/w? i have the same problem.
No it doesn't come out. It is connected to the drain pump from underneath. There is a YouTube video online that shows how to pull all that stuff out and clean it. Search for GE Quietpower 3 drain
