lpiatchek
#1 Posted : Monday, July 16, 2012 4:42:29 PM(UTC)
lpiatchek
my dishwasher starts but stops after 1-2 minutes. I was told to try cleaning drain. I was able to remove white cage in bottom of washer but cannot get the grey part out. should i be able to remove this and clean? if so, how do i get it out to clean it?
#2 Posted : Tuesday, July 17, 2012 1:18:15 AM(UTC)
A model number may help others help you.
Model Number Locator
calvinb
#3 Posted : Wednesday, May 22, 2013 11:27:38 AM(UTC)
calvinb
what was the problem with your d/w? i have the same problem.
Joetheplumber0289
#4 Posted : Tuesday, June 4, 2013 6:23:28 PM(UTC)
Joetheplumber0289
No it doesn't come out. It is connected to the drain pump from underneath. There is a YouTube video online that shows how to pull all that stuff out and clean it. Search for GE Quietpower 3 drain
