My waher comes to the end of the cycle and the clothes are still dripping wet. I ran it back through the spin cycle and found that the tub wasn't spinning. I took out all of the clothes and tried it again and sometimes it spun, other times it didn't. When I added clothes back into it while it was spinning, it slowed down as the weight got heavier. I was able to start the tub turning with my hand and it would engage and start to spin on it's own, although not very fast. I originally thought a slipping belt, until I looked and found that it didn't use a belt. From videos that I have watched, it seems to be acting like a slipping clutch, but I'm not sure. Can you help me?
Groups: APP Team
Hi. Most likely it is the clutch. The clutch Part number: 285785
Use the video clip for the instructions. Thank you. Post the results. Simon.
Well I replaced the clutch assembly and everything worked great for the first few loads. Unfortunately the problem came back. I think it may be related to weight, as the first few loads were smaller and used less water. Again though, the bin just needed some help to get started. I pushed it into motion and it continued to spin on it's own and soon it got up to speed. Any suggestions on what this could be?
Groups: APP Team
Hi.
Make sure there is no oil or grease in the clutch and spin tube area.Use the breaks cleaner spray if you have one.
Simon.
