I have 3 yr old GE Harmony washer. It suddenly start dripping inside the washer w/o even turning it on. I talk to one the technician and he mentioned that you need to back flush both pipes, other technician told me that it could be problem with water assembly valve. Is it easy to replace water assembly valve? how expensive this valve is? Need help.
